seized distributor hold down bolt
Old Jul 15, 2003 | 11:22 PM
91Z28-350's Avatar
I need some ideas. The hold down bolt is seized. I've been soaking it with penetrating oil for the past few days, no dice.
Gracias.
Old Jul 16, 2003 | 12:12 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Long breaker bar.
Old Jul 16, 2003 | 05:11 AM
ede's Avatar
ede
a little heat, or a little cold on the intake should help free it
Old Jul 16, 2003 | 10:39 AM
91Z28-350's Avatar
A breaker bar was the first thing I tried. I'll try some heat and/or cold. Thanks much.
Old Jul 16, 2003 | 10:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Also, don't be giving the breaker bar a long "pulllll". Doing that can induce a side-load that can strip the bolt head. You want to use a pulsing motion - like an air-powered impact wrench - to break the bolt free. Instead of a long pull, give a few short/hard pulls. Same for pushing. (Sounds like a dirty joke, eh?) That's why hammering on a ratchet handle or breaker bar works- it gives the bolt an "impact" which helps loosen it.
If you strike the breaker bar with a hammer, be careful of your eyes- the chrome can chip (chrome is hard but brittle) and little pieces can fly off into your eyes.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
86IROC112
Aug 17, 2015 07:57 PM
