identify 305
Old Jul 17, 2003 | 04:54 PM
imstress's Avatar
identify 305
can anyone identify this 305 engine for me?
numbers are 460778 a K is lower and to the right of the numbers and then a 22 further to the right.
I am trying to see if I can swap it for the one in my 86 T/A 305 LG4 5 speed. or should I just find a 350 in the junk yard and rebuild it?
Chuck
Old Jul 17, 2003 | 07:51 PM
Vader's Avatar
Check the casting numbers at www.mortec.com for details.
That one is a generic 1970's 305 smogger engine. The last time I compared prices, cast iron was going for about 3½¢ a pound, so if it has both heads it's probably worth about $13.00 (U.S.).
Just my opinion, but if you have to do anything to the engine below the deck, it's not worth spending a penny on a 305 - unless you're stuck in a 5-liter racing class or something odd like that. Even then, a different bore/stroke is better than what the factory provided.
Old Jul 17, 2003 | 08:11 PM
imstress's Avatar
Well the deal is the 305 in my 86 T/a is about had it, a few years back a freind totaled his nova with a newly rebuilt 305 less than 6k. He gave me the engine so I am thinking of swaping the two.
1) is it worth it?
2) will everything match up to the older block "like the temp senders"
Old Jul 17, 2003 | 09:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Only problem would be the flex plate ('86 has one-piece rear main seal), and dip stick (assuming the older block has it on the driver's side).
You'd probably be better off taking the $13 and putting it to better use, though.
Old Jul 18, 2003 | 04:27 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Bigger is better in this case. Why spend the money on a 305 when a 350 will cost about the same, and you'd get more out of it?
Old Jul 18, 2003 | 09:52 AM
imstress's Avatar
O.K. anyone want to buy a newly rebuilt 305 so I can make room to work on a 350?
poor thing just sitting around waiting for someone to luv it.
Chuck
db057
Apr 28, 2019 07:45 AM
angel2794
Sep 8, 2015 06:22 PM
buffaloman
Firebirds Wanted
Sep 7, 2015 09:47 AM
buffaloman
Camaros Wanted
Sep 7, 2015 09:46 AM
Formula_88AE
Sep 3, 2015 01:47 PM
