HELP! Bad oil leak!
Old Oct 11, 2000 | 06:33 PM
jm91rs's Avatar
HELP! Bad oil leak!
My brother's 92 rs v-6 is leaking bad. It is coming from up around the distributor. I have the distributor off right now looking at it, but all I can see is that is coming from around there. Please help. Any ideas
91 rs convertible, K&N, Edelbrock open element cleaner, 3.73, B&M shifter
Old Oct 11, 2000 | 06:35 PM
ede's Avatar
ede
try a new gasket on the distributor, i'd look at the oil senders too.
-=ICON MOTORSPORTS=-
Old Oct 11, 2000 | 08:45 PM
jm91rs's Avatar
I took off the distributor and there isn't even a gasket there. Should there be one. If there should, where did it go? I guess I gotta call chevy to get one. Autozone said that they don't carry it if there is one.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood
Old Oct 11, 2000 | 09:16 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There should be a rubber O-ring on the dist.
These ALWAYS leak on 2.8/3.1s. Very common.
If you touch it its probably hard as a rock.
Should be able to get one at the dealer or most auto part stores.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 11, 2000).]
Old Oct 12, 2000 | 08:06 AM
jm91rs's Avatar
Thanks, I'll give it a shot, but I know that there is no gasket on the distributor right now and there wasn't when I took it off. I guess if there is supposed to be one, that would cause an oil leak.
Old Oct 12, 2000 | 08:09 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Should be a grove below the base of the dist. for the O-ring.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
CamaroZ_85's Avatar
id just like to know what moron parts counterman said "we cant get it if there is one"
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 14, 2000 | 11:43 AM
jm91rs's Avatar
Ok..I got a new o-ring and a gasket for the base of the distributor. Now i gotta figure out where the number one cylinder on a v-6 is. Any one know?
Old Oct 14, 2000 | 12:59 PM
TELLEZ's Avatar
Did you check the oil pressure sendin unit? I replaced mine after an oil leak from around the distributor.
88 IROC-Z,L98 350 TPI, 700R-4 Tranny 2.77, K&N Filters, 126K Miles runs great. http://www.j-body.org/library/humor-...arearicer.html
Old Oct 15, 2000 | 12:34 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
#1 is the cylinder that is the most foward.
I belive on the 2.8s it is the front passenger side. (I don't have one in front of me )
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
xxx3man`
Sep 23, 2015 10:37 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mike_c
Aug 27, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
