Please help with code 45
Old Oct 13, 2000 | 08:58 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Tonight I was driving down the road and got blinded by my SES light. I ran it and it said code 45 I have no idea what that is and since I dont know what it is I have no idea how to fix it please help out. Thanks.
Member of NCTGA
North Carolina Third Gen. Assoc.
'89 Iroc-Z
305 TPI few minor things
5 speed
Lowered 2" and yes it is a pain to drive
Old Oct 13, 2000 | 09:46 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Code 45: Rich Exhaust.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROCZTWENTYGR8 (edited October 13, 2000).]
Old Oct 14, 2000 | 02:35 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
That would explain back fire. What would be some of the way to fix it? I just had a fuel pump put in do you think that that may be the problem?
Old Oct 15, 2000 | 10:40 AM
Vader's Avatar
89,
Since your TPI should have a MAF, most of the fuel curve is determined by RPM, TPS and MAF inputs, with minor offsets for temperature and other variables. It is much more common to have too little fuel delivery, so your problem is somewhat unusual. I would suggest checking fuel rail pressure and leakdown at shutoff. This may determine whether the rail pressure is correct while operating and if the injectors are sticking or leaking extra fuel when they should be closed. Just for argument's sake, you might want to test the TPS voltage through the entire range of operation to see if there are any "dead" spots in it's travel.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
