Big cam, base timing, engine rpm
Old Jul 18, 2003 | 02:51 PM
OMINOUS_87's Avatar
The engine is as follows:
Superram, 383, 224/230 .537/.544.
The combo is not crazy extreme but likes to idle at about 850-900 rpm in park. I am starting with an ARAP base bin. Right now the car is idling real well, mid 130 BLM and no knock counts. My question is about the base timing. We all know that the tan/black wire needs to be disconected and base timing should be 6-8 degrees. Ok so now, I set my base to 6, I am having no problems, but i set it at about 900 rpm, is this fine?
So basically, is there a difference between setting my base timing to 6 at 900rpm Vs. 6 at the factory 550rpm? Should i be in park or drive? Anything else i need to know?
Thanks for the help guys!
Old Jul 18, 2003 | 02:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No, the RPM doesn't really matter, over that small of a range; when you disconnect the wire, there's nothing that changes it as a function of RPM, like there would be with a centrifugal advance distributor. Makes no difference what gear it's in, for the same reason.
Just to assure yourself, rev the motor with the wire disconnected; you should see esssentially no change in the timing.
Seems to me like you might need a significantly different timing curve with that much different of a motor than stock, though.
Old Jul 18, 2003 | 03:42 PM
OMINOUS_87's Avatar
RB83L69
Thanks for the answer. I didnt think setting it at a higher rpm would be an issue but I just wanted to throw it out for comments.
I have a significantly different timing curve, the timing curve in my bin is far from the ARAP curve.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
