Can anyone cross my heads casting number?
Old Oct 15, 2000 | 12:55 PM
Jas89TTA's Avatar
I was wondering if someone can tell me what type of heads I have on my car and what year. The casting number on both heads 14101083 are suppose to be L98 Cast IRon heads off a 92 Camaro that had the TPI 350.
I've installed them on my 87 Trans Am that I put a 350 in but have been buring oil since the rebuild. The machine shop suggested to pull the intake as that may be where the oil is getting into the engine. I pulled the PVC valve and it is wet with oil is that normal after 2000 miles? Right now I'm n the process of pulling the intake but wanted to make sure these are the correct heads for a TPI engine. Thanks, Jason
Old Oct 15, 2000 | 01:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
From the Mortec site.
14101083...87-up...350..........Gen.I, also used on crate motors, 285 or 300 hp, 64cc chambers, 72' center manifold bolt angles
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
camaro71633
Sep 1, 2015 10:24 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
dcbsracing007
Aug 18, 2015 07:24 AM
