degrees timing?
Old Oct 15, 2000 | 08:34 PM
TK87TA's Avatar
degrees timing?
i have an 87 T/A 305 4 bbl. i was wondering what i should be running timing wise. i always use 93 octane gas, and am about to switch to a 180 degree stat. i am running 2-4 degress on average with the 4-pin wire connecor dissconnected
1987 Trans Am
Black & Gold
Light Mods
Old Oct 15, 2000 | 09:46 PM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
I beleive 6 degrees btdc is the factory recommendation... I run mine at 7 or 8...
Old Oct 15, 2000 | 10:04 PM
84IROC's Avatar
If you want to find out the max you can run bump it up to 10* and drive it. If it does not try to detonate try bumping 2* more and drive it again. If it does detonate back it off 2* and drive it. You do not want it to to start to detonate because when it does the ECM backs the timing way off and gradually brings it back up, so you want to keep it from doing this for ultimate performance.
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
