how do i check for a bad oxygen sensor?
Old Jul 19, 2003 | 02:31 PM
19WS6T/A91's Avatar
isnt there some way to see if the o2 sensor is still good?
Old Jul 19, 2003 | 04:43 PM
ede's Avatar
ede
check out put with a DVM, i beleive if there is any out put it would be good, but since it varies i don't think you'll find a set value that is makes it good, or bad. check your manual for readings i may have it wrong.
Old Jul 20, 2003 | 07:26 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
They should be putting out .1 to .9 volts with eng running.
If the sensor is out of the car, you can blow propane across the tip and read a voltage increase. That tells you if it's completely dead or not. Doesn't tell you much more.
They can be operable but sluggish.
IMHO; If your concerned and/or know it hasn't been replaced in 20-30K miles, replace it. They're like $20-30.
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
squiggy2
Aug 9, 2015 09:30 PM
