Some more parts ?'s
Old Jul 19, 2003 | 04:39 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Some more parts ?'s
Im just all messed up with what Im doing...yeah yeah call me dumb.....anyways,
I got the LT1 cam with the .201/.447 .208/.459 specs
Im using my stock heads.....which Im not going to be removing from the block. Im going to replace my springs with .500 max lift and also going to be putting 1.6 roller rockers....that will put the lift of the cam to .203/.477 .210/.480
WILL THIS WORK?
Do I have to buy self-aligning rockers? my old ones are not.
Old Jul 19, 2003 | 04:40 PM
other
Old Jul 19, 2003 | 06:06 PM
boogie's Avatar
Your heads have the narrow pushrod slots so self aligning rockers are not needed.
You will probably need to elongate the pushrod slot and you may have to cut the guide bosses down to increase retainer to seal clearance when running 1.6 rockers. Check these things out before you run it.
Old Jul 19, 2003 | 06:21 PM
so how come ive been reading that I need to use self-aligning rockers?
Also Ive read about people putting on 1.6 rockers with no problem or atleast they havent posted about there problems.
I can just do what Im wanting to do and be done with it? you said "probably"
Old Jul 19, 2003 | 06:23 PM
forgot to add the pic....I can still use self-aligner's with no problem though, right?
Old Jul 19, 2003 | 09:12 PM
boogie's Avatar
The heads in the picture have the narrow slots which serves the purpose of aligning the pushrods. If you install self-aligning rockers you now have two methods of aligning the pushrods which can lead to binding. If you already have and want to run the self-aligning rockers in the picture you need to open up the pushrod slots in the head just like the late model heads have that came with self aligning rockers.
Heads vary from casting to casting, one will accept more lift without machine work than the next. My experience with 1.6 rockers has most often lead to the pushrod rubbing the head on the spring side. I would install and set the lash on one exhaust rocker, rotate the engine a full revolution and watch for pushrod to head interference. The only way to know for sure about retainer to seal contact is to MEASURE it. anything over .450 to .460 lift needs to be checked.
Old Jul 20, 2003 | 12:28 PM
OK, so I dont have to have self-aligning rockers....the push rod slots keep the rod and rockers aligned cause there is no "play" area for the rod to move around. I can understand that.....
but what about using 1.6 rockers with my stock heads? will that be OK? I will have new springs that can handle the lift....or should I just ot even bother with 1.6's and go with 1.52's?
what are my rocker size anyways?
thanks
Old Jul 27, 2003 | 09:50 PM
are you dead positive that I dont need self-aligning rockers? cause Im about to order some..
Old Jul 28, 2003 | 09:07 PM
yeah ok........whatever! ...LOL
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
