Number one cylinder on a 3.1?
Old Oct 15, 2000 | 04:58 PM
jm91rs's Avatar
Distributor is out and now I need to know which cylinder is number one. Is is passenger side or driver's side?
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood
Old Oct 15, 2000 | 06:08 PM
ede's Avatar
ede
#1 would be the plug on the drivers side towards the front
-=ICON MOTORSPORTS=-
[This message has been edited by ede (edited October 15, 2000).]
Old Oct 15, 2000 | 07:25 PM
jm91rs's Avatar
Ok, now how exactly do I line up the distributor to get the car running?
Old Oct 15, 2000 | 09:14 PM
ede's Avatar
ede
match up the marks on the balancer at zero. make sure the valves are closed on #1. put the rotor pointing to #1 plug wire. put distributor in engine.
Old Oct 15, 2000 | 11:21 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
To elaborate a little...
I usually pull the #1 plug out (whichever cylinder is the farthest foward is #1)
Disable the ign. (pull the coil wire off)
While putting your finger in the #1 plug hole have someone bump the key until you feel compression pushing your finger.
Finish rotating the engine by hand until the timing marks line up at TDC.
Drop the dist in making sure to allow for the gear to mesh, so when its all the way down the rotor points at #1. (you must have the rotor a little ahead of #1 so it can mesh with the cam gear.)
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 16, 2000 | 10:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Ack, NO! Number one is the frontmost passenger side cylinder!
Okay, well technically it's that way on a 2.8, but there's no major differences between a 2.8 and 3.1. And yes, I am sure of #1 being the front passenger on a 2.8.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
codeysabatini
Nov 10, 2015 04:07 PM
Springster
Sep 13, 2015 01:38 PM
