Heater core replacement ?'s
Old Jul 20, 2003 | 12:23 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I think my heater core is bad. I started to notice a wierd oily stain on my passenger carpet. Also, coolant is mysteriously disapearing. I did a search and I have some questions about it.
Does anything on the driverside have to be replaced or removed or otherwise worked on?
How much is the heater core?
What tools and supplies are needed?
Is it simply a bolt on and off procedure?
Thanks,
Matt
Old Jul 20, 2003 | 12:56 PM
ede's Avatar
ede
other than being harder than hell to get to it isn't hard job. call parts stores i nyour area for prices. i'd say 1/4 drive universal sockets will make life easier for you. it's mostly a passenger side/center sort of access, not driver side. read in your manual, it ought to have a pretty good R&R for the heater core.
Old Jul 20, 2003 | 01:37 PM
Matto'85TA's Avatar
Thanks. I picked up a core for $30 bucks. Not genuine Gm but it is OEM. Apparantly Pep Boys only selld OEM stuff.
Thanks,
Matt
Old Jul 20, 2003 | 07:01 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I agree with ede, it isn't that complex of a job but it is a big PITA to get it in and out. Be careful not to bend the new heater core lines. They will bend pretty easy if you start pushing on it too hard and believe me you may get to the point where you just want to shove the thing as hard as you can. Don't do it. It isn't a job for a Preacher. WARNING!! A few choice words may be used in the installation of this product. That would be the label on the box when you buy a heater core.
Old Jul 20, 2003 | 07:06 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Not a bad job at all, ede has it summed up pretty well, but to put it into perspective, I did mine about a week after hernia surgery, without causing myself any problems. I basically sat on the ground beside the car with the door open, and I could get to it all by just leaning a little bit into the car.
The labor guide says it's like a 3.5 hour job (can't remember for sure!) and I can easily do it in about 2.
Good luck
Old Jul 20, 2003 | 08:35 PM
Matto'85TA's Avatar
Well, I got it done today. Took about 3 hours. Would've been a lot less if the ?-shaped hose came off easier or if I could find that hidden top bolt to the cover. I seriously felt like wanting to track down the designer if this thing and shooting him, though. Was a PITA but very do able.
Thanks for the help.
Matt
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
