Engine starts... a little TOO fast...
Old Jul 20, 2003 | 02:12 PM
92RSSlowmaro's Avatar
Wierd. Got out to my car this morning and the motor started almost the instant I turned the key. Granted this is not an undesirable affect, but is it the sympton of an abnormal condition of any sort?
Old Jul 20, 2003 | 02:14 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Re: Engine starts... a little TOO fast...
I believe it is a symptom of paranoius driverus
Old Jul 20, 2003 | 02:17 PM
Re: Re: Engine starts... a little TOO fast...
LOL
Yea well I thought maybe something abnormal, yet not neccesarily harmful may have been happening.
Old Jul 20, 2003 | 02:19 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
i think its also called a good starter
maybe u just got the touch
Old Jul 20, 2003 | 02:20 PM
Well its not like my starter motor has much compression to work against.. not to mention 2 less pistons
Old Jul 20, 2003 | 02:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
with my older carbed motors, it started REALLY quick.
just get in,
turn ign on,
pump gas to floor one time. on my carb that would spray some fuel in, and it would set the elec choke.
flick the key for less then a sec, because it fired right up....
the only reason most FI carbs take a sec to start is that the computer has to know the engine is spinning before it starts spraying fuel.
Old Jul 20, 2003 | 03:11 PM
llvll4l2c91350's Avatar
:sillylol:
Old Jul 20, 2003 | 04:07 PM
Dr G's Avatar
I believe it is a symptom of paranoius driverus!!
I'll have to consult the journals on that one!! LOL.
Seriously though 92RSSlowmaro, I haven't heard of any "problem" causing this. Perhaps some of the moderators might know.
BTW When I installed a mini gear reduction starter motor in mine I noticed it starter far quicker. Also, no heat soak issues and goodbye header clearance issues.
Old Jul 20, 2003 | 06:50 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Sounds like a good problem to have. I wouldn't worry about it until it didn't start at all.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
