help!!! Broke bolt off when taking TPS off
Old Oct 16, 2000 | 04:52 PM
89ride's Avatar
How do I get the rest of the bolt out of the threads inside the throttle body??? Am i in trouble or easy remedy please help. need help before wife gets home Heh heh.
Old Oct 16, 2000 | 07:20 PM
ede's Avatar
ede
see if you can find a left hand drill bit and a screw extractor the right size for your broke bolt. lot of times the left hand drill will bring what's left of the screw out. if it doesn't then try the extractor. be extra careful, they break easy and then you'd have more problems than you do now. if that does work try to drill it out with the tap drill size and retap the hole.
-=ICON MOTORSPORTS=-
Old Oct 16, 2000 | 08:15 PM
89ride's Avatar
Thanks ede for the help on the screw extraction procedure. one screw will have to hold it till i get that sucker out
Old Oct 16, 2000 | 08:57 PM
Vader's Avatar
89,
That probably never would have happened if the screw had anti-seize on it.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
mdtoren
Aug 16, 2015 05:45 PM
