TA won't stay running
Old Jul 21, 2003 | 06:19 PM
Copper85Ta's Avatar
HELP, I have an 85 TA, 350 Corvette engine with 305 heads and tune port injection. Lately my car starts up fine, but will not stay running unless i give it gas right away. I have put in a new oxygen sensor, tpi, fuel filter, mass air flow filter, am putting in the best gas I can buy and am putting in high octane additives. Also my car stalls at stop signs and pulls back on the highway. CAN ANYONE PLEASE HELP WITH YOUR SUGGESTIONS?
Old Jul 21, 2003 | 07:01 PM
matt_82transam's Avatar
Car: 82 T/A
Transmission: th350 w/ high stall C.
i have the same problem because i did plently of mods, then I bumped up my fuel pressure and the problem went away. However everyone says that the fpressure thing only comes into play when your at WOT, however Im sure 2-3 psi up or down will effect idle and regular driving. So try to bump the pressure up a bit to see if it is that. I read in your sig. that you changed your fuel filter...well unless something got plugged up in process, fuel wise it could be your fuel pump.
Old Jul 23, 2003 | 10:16 AM
Copper85Ta's Avatar
Thank you for your advise! I do have a question for you though. What does WOT mean?
Old Jul 23, 2003 | 10:18 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Wide Open Throttle
Old Jul 23, 2003 | 10:49 AM
Copper85Ta's Avatar
apo_bailon15
Mar 28, 2016 05:20 AM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
Sherpajames
Aug 7, 2015 06:56 PM
