LOUD SUCKING SOUND!!
Old Oct 15, 2000 | 02:33 AM
FormulaGod's Avatar
HELP!! My car is making a very loud sucking sound after i put together the engine. Its tpi with edel runners and base, there seems to be no leaks!! Could it be the IAC? Anyone have this problem before?
[This message has been edited by FormulaGod (edited October 15, 2000).]
Old Oct 15, 2000 | 05:55 AM
Steves ZZ5's Avatar
Did you also just switch over to an open-element air filter directly off of the throttle body? (Only pertains if you're using a Speed Density setup obviously).
Other than that, it would help if you tell us a bit more about your car/setup. You are sure it's an air sucking sound you hear and not a cavitating water pump or possibly the alternator or a belt that's mis-adjusted?
Is it a high pitch sound or a low continuous whoosh?
At what RPM ranges is it more or less noticeable, and does it change frequency at different RPM's?
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger"
The Road Warrior
Old Oct 15, 2000 | 10:15 AM
pvknight's Avatar
Dunno much about this, but it could be a vacuum leak according to the sound.
Brian
Old Oct 15, 2000 | 02:12 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
First check what ZZ5 says, if it turns out just to be an air hissing sound, thats not the air intake, do one of 2 things. The cheap, no so elegant way of doing this is to cut off a small piece of garden hose. Hold one end to your ear, and the other end use to probe around the engine. Find where the hissing is loudest. The visually inspect that area, the problem should be obvious. The more elegant way would be to buy a stethascope and do the same thing. This should help you locate the problem.
Good luck
Corry
Old Oct 15, 2000 | 11:44 PM
CamaroZ_85's Avatar
i say if shes constantly makin a loud sucking sound, shes a keeper
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Oct 16, 2000 | 04:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you were from Texas, you could blame it on NAFTA.
Seriously, though, really sounds like something was left off when you put it back together.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited October 16, 2000).]
Old Oct 17, 2000 | 08:17 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I would say check for something disconnected, but on the 350 (mine is TBI) It turned out to be some bad injectors. I don't know a thing about TPI though...
Good luck,
Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, platinum plugs, chevy caprice 350 chip.
Old Oct 17, 2000 | 08:19 PM
nebulous's Avatar
Car: 91-Trans Am-WS6
Engine: L05 350 - ATI 9psi
Transmission: Pro-Built:Street/Strip
The exact same thing happened to me when i put back together my 305 TPI. As far as I could tell it was not a vaccum leak, and there was no power decrease. I would love to know.
Old Oct 17, 2000 | 09:34 PM
fast89's Avatar
I also have a high pitched whistle noise that I have found is coming from the plenum and TB. I believe that it is probably from the porting of the plenum and the larger 52 TB. Also, since I ported the plenum I might have a UNsmooth surface that might need to be smoothed down near the TB/Plenum opening. Or it could be because I am getting so much more air flow into the plenum.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
loud91rs
Oct 5, 2015 10:05 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
