why is my engine skipping!!!!!!????????
Old Jul 24, 2003 | 04:21 PM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
I have 85 Z28 with a 383 stroker crate engine in it and the just eats spark plugs. I know it is time to change the plugs when the car starts skipping. However this time, I changed the plugs and it is still doing it. It sounds like crap when your going down the road nor do I have as much power as I should. Any help?
Old Jul 24, 2003 | 04:23 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: why is my engine skipping!!!!!!????????
It's warming up for hop-scotch?
What plugs are you using? Have you checked the wires?
The plugs could be too cold, the wires could be bad and the spark plugs are only doing what they can for however long they last.
Old Jul 24, 2003 | 07:32 PM
Car: 85 Z28
Engine: 383 Stroker
Yes, I checked the wires too and they were all fine and connected (and no, they aren't connected to the wrong plugs). The plugs themselves are autolite AR134's, although I was using Accel 576S. I also don't know what causes the motor to eat plugs so fast. Do you have any thoughts on that?
Old Jul 25, 2003 | 02:23 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its carbed, maybe its running excessivly rich or lean? That could explain both the ingestion of spark plugs and lack of power.
What do the plugs look like?
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
