Need help picking cam for 383/SuperRam setup
Old Oct 16, 2000 | 10:48 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I need some help in picking out a cam for the setup Im building. Here are the details.
[*]383 - non-roller - 10:1 compression[*]TFS 23* heads - max lift on springs is .520 but I will upgrade if benneficial[*]Crane 1.6 Roller rockers[*]Complete portmatched SuperRam[*]T56 tranny going in during swap[*]Have custom chip now and will make a new one[*]Stock 48mm TB that will be replace with a 58mm[*]3.73 Auburn pro posi rear end.[*] Edelbrock TES headers with Dynomax catback
Goal for car is to have kick a$$ daily driving with occasional track runs.
Mark Lock
- 86 IROC-Z - My car, mods and ET's
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Oct 16, 2000 | 05:42 PM
Box of Rocks's Avatar
Lock 'n Load,
Nice setup. If you want to use those 1.6 rockers, you'll need new springs, but this cam will make it worth it.......You'll smile all the way down the track as you knock-off 12.90's.
It's the Comp Cams Extreme Energy 284.
Duration at .050 is 240/246 with lift around .507/.510.
That's why you'll need new springs.
That series from Comp is very, very nice....
Fast/delayed intake valve opening rate with smooth exhaust rate. Bleeds off very little compression, cuts down on overlap, makes TONS of power and torque. Your 383 will think it's 11 to 1 compression, but will still run on pump gas.
I'm using the smaller 274 grind in an early 327 - and it is perfect. Lumpy idle scares old ladies....makes young ones wet.
BOR
Old Oct 16, 2000 | 07:51 PM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Hey BOR,
Lack of Essence is causing me to have withdrawals.
Does COMP Cams have that cam spec in a hydraulic roller?
I'm thinking the ZZ4 cam in my car is needing an upgrade, even though I haven't seen my cars full potential yet.
Sparks a flyin'
Old Oct 16, 2000 | 08:48 PM
lock's Avatar
Car: 86 IROC-Z
Ive been hunting some one with a 383/SR setup. Reason is that Ive read 112 lope seperation is best for the SuperRam. I think that cam is a 110 isnt it? I dont have my magazine handy.
Old Oct 16, 2000 | 08:49 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Oh my god that's a big cam...sounds perfect for my 400 That cam makes the 219 roller I wanna put in the motor look like a wuss.
Old Oct 17, 2000 | 03:07 PM
lock's Avatar
Car: 86 IROC-Z
Any other thoughts? I was hoping for some good conversation to help me learn more about what characteristics of the cam will do to help my setup.
Old Oct 18, 2000 | 08:42 AM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Hey Lock...I would use the LPE/Accel SuperRam 213 cam. Thats what IM using in my 406, Its designed for that intake. I think it would be perfect for what you have and are wanting out of the motor.
It has 224/234* duration 467/488 lift. The opening and closing events are timed for the SuperRam intake using a 383/406 SB. so why not use it to your advantage. That cam will pull great to 6000 with that setup.
I have the 23* trick flows for my 406. I havent installed this combo yet so i cant tell you how it runs.
Go too the Lingenfelter website there is some info there on the camshaft.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
[This message has been edited by MikeH (edited October 18, 2000).]
Old Oct 18, 2000 | 09:35 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
well lock, the one i've personally chosen to start with is comp cams extreme no. 12-243-3. duration is 226 and 234 at .050 and lift is .480 and .498. i don't remember the lsa at the moment, but i believe it was around 112. anyway, it's what i'm chosing for my 383 until i spring for the extra money to switch to roller cam. just my opinion, i could be ....., nah.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
camaro71633
Sep 1, 2015 10:24 AM
