starter motor shims need quik answer
Old Jul 25, 2003 | 05:11 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Hey im bout to go shim this starter motor on my car. Its making this clicking sound sometimes. Problem is i got this shim kit and I have 1/64" 1/32" and 1/16" shims. Which one to fit on a 92 RS with 305 and yes it has AC well thats the the guy at O'Reillys asked me for no reason. But I would appreciate any knowledge here thanks
Old Jul 25, 2003 | 05:34 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
uuuh.... you put whatever shim you need in there.
use whatever puts the correct mesh pattern there..
the orileys guy asked about AC because hes a idoit and needs to know that to put the car into the computer.
Old Jul 26, 2003 | 04:49 AM
ede's Avatar
ede
unless you just R&Red starters you don't need shims, in other words if your clicking problem just developed you don't need shims.
Old Jul 26, 2003 | 05:41 AM
gmsmallblockguy's Avatar
Yup if it is just clicking and that just started it isn't shims you need it's a solenoid or a better connection to it or more juice.
Old Jul 26, 2003 | 07:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
When I went to the stealership looking for starter shims for the 88 that I rebuilt they told the car didn't come with any. First time I've heard and seen that. I guess it doesn't need any cause I have the proper clearances without.
Old Jul 26, 2003 | 07:40 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
There is a good article in the new Camaro Performer magazine about the correct use of shims and when they are needed, my car didn't come with any and I think unless the factory screws up the machine work it won't need any. But if it's just clicking and the starter was already on the car then gmsmallblockguy had it correct.
Old Jul 26, 2003 | 08:06 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes usually you just use a 1 small shim with a non OE starter. If the manufacturor machined the nose cone correctly you wouldent have to use one at all, tell that to the parts store people, heh
jhawkeye
May 25, 2022 06:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
milk
Aug 10, 2015 06:26 PM
