Swapping in a non-roller cam in a roller block
Old Oct 19, 2000 | 03:25 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I am aware that I must change my pushrod length. I there anything else I have to do?
1986 CAMARO Z28 -> 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, 6 quart oil pan
Old Oct 19, 2000 | 03:48 PM
ede's Avatar
ede
cam and lifters, eliminate the spider. not sure if you can keep or need to keep the retainer that bolts to the front of the block. it should be easy for you to see and figure out what you need when you have it apart.
-=ICON MOTORSPORTS=-
Old Oct 19, 2000 | 06:05 PM
MikeC.86Roc's Avatar
Why would you want to get rid of a roller cam?
junkcltr
Aug 2, 2019 11:12 PM
midge54
Jan 29, 2017 07:00 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
