Have no idea what compression ratio this engine is gonna make, can you tell me?
Subscribe
Oct 3, 2000 | 12:02 PM
I just finished my 383 with 5.7 rods, keith black flat top pistons and AFR 195 heads (dunno cc's) anybody know where my compression ratio should be?
Reply 0
Oct 3, 2000 | 12:14 PM
if you tell me the CCs on your head,what type of gasket did you use,and if you had your block decked i can figuer out what it is. if you have 64 cc chambers, stantard gasket and a lil bit taken off the deck you will have 10.6:1, if you give me some detales i will tell you.
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Reply 0
Oct 18, 2000 | 02:44 PM
76CC heads
Reply 0
Oct 18, 2000 | 06:28 PM
Here's an on-line calculator. Have fun.
http://www.brcpistons.com/calculations.html
Mike
Reply 0
Oct 18, 2000 | 06:53 PM
I hope its not injected...
Reply 0
Oct 18, 2000 | 09:37 PM
Mike, why do you say you hope it's not injected?
Reply 0
Oct 19, 2000 | 06:15 PM
Cuz the AFR 195's wont work with a stock tune port base manifold. The intake runners have more opening tward the top.
Reply 0
Oct 19, 2000 | 06:50 PM
What is the piston compression height(in inches) and the piston volume (in cc's)? What is your block deck height and what gasket are you going to use?
I have a spreadsheet in Excel that will give me the exact CR.
Reply 0
Subscribe
