305 tpi, bigger restriction heads or tpi???
Old Jul 27, 2003 | 02:38 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm just trying to figure what's the bigger restriction on my motor ('90 tpi 305) the intake or the heads. I have a line on a set of L98 aluminum heads and I'm considering these heads with a beefier than stock cam. I just want to know if the changes will be worth it or if the stock tpi will just end up choking things up anyays. Thanks.
Brian
Old Jul 28, 2003 | 05:07 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
Any thoughts on this topic?
Old Aug 13, 2003 | 02:40 PM
smithtc's Avatar
Did you get the head/cam? If so, how did it work out?
I believe the heads are the bigger restriction...
Old Aug 13, 2003 | 04:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Restriction to flow (as measured on a flow bench), or restriction to power?
Simple flow, probably the heads. Restriction to power, though, brings the pulse tuning effect of Tuned Port Injection into play. So, increasing the flow capacity of the heads may improve flow, but the RPM limitations of TPI will smack the improvement hard at the same RPMs your power is being restricted now.
Better heads, better exhaust, ported plenum, shorter/fatter runners, fuel pressure & PROM tuning would have a significant effect on power, though.
gta90
Sep 15, 2015 04:00 PM
lakeffect2
Aug 23, 2015 08:44 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
