anyone know the answer?
Old Jul 27, 2003 | 05:08 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
My car has a pinhole leak in the upper radiator hose that i just noticed. So as a patch to get me to the parts store i wrapped some duct tape around it and filled the rad up a little. I let it run for a while waiting for the temp to get high enough to open the thermostat and see how badly it still leaked. I left the rad cap off to burp the system if any air had gotten in while the coolant level was low and let it run for about 10 min. well it didnt get really hot so i gave it a little throttle and then looked at the rad opening and the coolant had foamed up and was trickling out the top of the rad. The patch worked and the hose didnt leak but the thermostat did open because the hose was full and hot and when it started to flow into the rad it started the foaming. My question is, what is causing the coolant to foam up? Any ideas?
Old Jul 27, 2003 | 07:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Pressure.
Replace the hose. Fill with coolant and be done with it.
Duct tape isn't even a temporary solution to your problem.
Old Jul 27, 2003 | 07:51 PM
Notch-boy14's Avatar
Car: 1991 trans am GTA
Engine: 305 tpi
thank you mike. do not give new meaning to the term "duct tape and zip tie racing"
Old Jul 28, 2003 | 08:05 AM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
pressure??? pressure makes the coolant foam up??
and again the duct tape was a bandaid for the trip to the parts store to keep as much coolant from leaking as possible.
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
