LT1 Cam in a TPI?????
yes, my cam is a LT1 cam but it is in a TBI motor. You should have better results in your TPI motor but will need a different computer chip to get it's full potential...as you would for any higher lift cam.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The LT1 cam is almost identical to an L98 cam with 1.6 rockers on it. No chip swap is necessary. I believe on the 96-97 LT1's, it has a longer pin on the front that you'll need to change to the shorter pin. There are different LT1 cams depending on year, but I think the one to get is the 96-97 LT1 cam or 96 LT4 cam (the regular one, not the HOT cam), as it has better duration and lift numbers.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Beast,I installed an LT1 cam in my 89 L98 this summer.I just got it running yesterday,and it seems to be alot more responsive.I haven't driven it yet,but I will by the weekend.As far as the dowel pin in the front of the cam on the LT1,it is used to drive the water pump.It sticks out about .600"and all you have to do is tap it back into the cam so that it is sticking out about .300"like the L98 cam.If you can't tap it in far enough,then you can grind it down till you reach the .300".The part # for the LT1 cam is 12551705 and probably cheapest at www.gmpartsdirect.com
We need Perry Mason
We need Perry Mason
Thanks alot for the info. I was considering buying the crane LT1 cam that was for sale for $90 on ScoddginDickeys clearance sale, http://www.sdpc2000.com/sale.htm but I phoned and they were all out already. OH well thanks anyways.
CanBeast,
FYI, the longer pin was installed on all '94-on camshafts in the LT1, LT4, and L99 ("Baby LT1"). The '92-'94 Aluminum head engines had the shorter dowel. The dowel can usually be pulled and replaced or tapped deeper into its recess to the correct depth.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
