oil pan for GTA
Old Oct 11, 2000 | 10:13 PM
88GTA's Avatar
oil pan for GTA
I'm having some trouble finding the right oil pan for my car. It is a GTA with the 305 TPI engine and 5-sp. My mechanic has tried 3 pans from the dealer and 2 pans from the junk yard. None of them fit. The parts computer shows the same part number for 5.0 TBI, 5.0 TPI, and 5.7 TPI but the diagrams all show different pans. A difference in the pans is that the drain plug for my pan is on the passenger side and all the other pans have had the plug on the driver's side. I have been without a car for almost 2 weeks now, I need some help
Chip
Old Oct 11, 2000 | 10:47 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
It doesn't matter where the drain is.
All that matters is the pickup to pan relation.
Is the drain location the only difference??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 11, 2000 | 10:49 PM
Vader's Avatar
88,
If the pan fits the engine other than the drain plug position, what difference would it make if your plug were on the "normal" side? I'm guessing that there are soem other fitment issues, but you didn't specify.
Remember that the '86 and later pans will be sized for a one-piece rear main seal. I'm guessing your parts team is looking at the correct year, but I just had to throw that one out there.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 12, 2000 | 06:17 PM
88GTA's Avatar
I know that the drain plug doesn't make a difference. So far my mechanic has not given me a whole lot of info other than the pans don't fit. I don't know where the clearance problem is. He did tell me that the bolt pattern is correct but I don't know anything else. I was hoping that someone else had had this problem before and would be able to help.
Chip
Old Oct 12, 2000 | 09:33 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Hey Chip, is that the stock engine? I've looked in a couple of places and I find the same part # for all the engines. I also see no differences down there that would lead me to believe that a different pan was needed. (this is all under the assumption that it is an '88 GTA). See if you can get some more info from your mechanic. Also see if you can snag the casting number for us.
Old Oct 20, 2000 | 10:28 PM
88GTA's Avatar
Thanks for your help guys. I finally got it taken care of. I had to take it to a machine shop and have them cut out the damaged section and weld in a new piece. Good as new. Now if I can just get the clutch to work.
Chip
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
camaro71633
Sep 3, 2015 03:56 AM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
