what compression ratio
Old Oct 21, 2000 | 01:30 AM
nelliesIroc's Avatar
I plan on getting vortec heads to put on my 350 i'm building but need to know what compression ratio i'd be looking at. I plan on getting trw forged or silv-a-cast pistons. Also what type of piston should I get? I plan on this being a daily driver but I also want good power so what compression ratio should I be shooting for I'm running a carb if that helps at all. I'm kinda new to this so any help would be appreciated.
Old Oct 21, 2000 | 07:17 AM
Lounge Lizard 6's Avatar
If those heads are 64cc and you have zero to near zero deck height you'll be looking at 9.8-10:1 depending on the head gasket.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Oct 21, 2000 | 10:23 AM
GOLD85's Avatar
i would shot for 9.5:1 for a street motor. with 64 cc chambers, regular head gasket, unshaved deck and flat tops pistions with 4 valve relefs your looking at 9.5:1. you should make damn hell a$$ power with this and still run pump gas
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
