Nothing but grind
Old Jul 29, 2003 | 04:47 PM
1mean99grandam's Avatar
Nothing but grind
When I go to start my 2.8L automatic 1987 Firebird (all info), the starter just goes into grinding mode - very annoying. Car doesn't start or try to turn over. So I reach under the car with my trusty persuassion tool (a hammer) and tap on the starter. Go to start it - no grinding, but it sounds like fan blades cutting through air. Try to start again, goes to grinding.
Obviously, it's time for a new starter, but could the flywheel (or what ever it is called) be damaged too? Could the flywheel have frozen, and what would cause that? Is that difficult to replace/fix?
Old Jul 29, 2003 | 05:28 PM
gmsmallblockguy's Avatar
flywheel might be missing teeth you won't know till you go look.
It is bolted to the crank so if it is "frozen" then so is your engine.
Old Jul 29, 2003 | 06:41 PM
ho can I check to see if the crank is frozen?
Old Jul 30, 2003 | 09:40 AM
turn the crank pulley with a socket and breaker bar CLOCKWISE
Old Jul 30, 2003 | 10:12 AM
HA HA! THanks!
Old Jul 30, 2003 | 08:29 PM
crank turns. that's a good thing. I have a new starter, now to get it in and check the flywheel
Jorlain
Oct 8, 2015 01:57 AM
hdis2002
Sep 8, 2015 02:52 PM
solocus
Sep 2, 2015 12:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
hokis
Aug 9, 2015 03:57 PM
