oxygen sensor
Old Jul 29, 2003 | 11:47 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
oxygen sensor
Any tricks at getting this out?
I found enough room to do the initial 'break', but not enough room even on the 12 point end of the wrench to get a hold if it to turn it again.
Break lines are in the way, the spark plug wires/loom are in the way.. the A Arm is in the way. The bolt flange for the exhaust pipes in the way.
Only easy way I can see something working is a deep socket with a side missing?
is this the special O2 sensor removal tool?
Old Jul 30, 2003 | 12:26 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
pretty much my friend just had this make shift one that wasnt even really a deep socket but same sort of idea. It was really long and just had a slit cut down the side. With it it took about 5 minutes to change the sensors.
Old Jul 30, 2003 | 01:51 AM
waltersb's Avatar
Suppose I could just go buy a deep socket and grind a side off..
I've already loosened it, just can't turn it any more.
just need a grinder... it would take a long time with a file.
Old Jul 30, 2003 | 05:10 AM
ede's Avatar
ede
there's sockets made for it as well as wrenches, crowsfoot wrenches. just a matter of finding the right tool, or several tools to fit and provide clearance.
Old Jul 30, 2003 | 07:16 AM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
Princess Auto has those o2 sockets here in London. Try the location in Langley. It is cheap and it works great!
http://www.princessauto.com/PAcountr...&INF=lan&SPC=1
Part #'s 2990140 $12.99 -- ratchet wrench crowsfoot stlyle
2990254 $7.49 -- standard style socket with slot
tj
Old Jul 30, 2003 | 05:43 PM
waltersb's Avatar
went and bought a socket for the O2 sensor.
$15.. no biggie
till I dislodged the fitting from the hose on the pressure fuel line replacing the O2 sensor.
Thanks for the help guys
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
