Edelbrock Valve Cover Question
Old Jul 30, 2003 | 03:43 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
On the edelbrock valve covers there are only two holes. Both for the pcv valves. But on my valve covers there are 3 holes including the oil fill hole. So my question is, is that pcv hose in the pic that runs from my valve cover to my carbuerator could I just get rid of that and not have that hose there? Would it hurt anything? Thats it.
Old Jul 30, 2003 | 03:46 PM
warrior_91's Avatar
Car: 86 T/A
Heres the pic, sorry
Old Jul 30, 2003 | 03:48 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
ok so it has the same number of holes - an oil fill hole.. so just pull the breather out and fill oil in there... keep the pcv valve.. it vents the crankcase and removes combustion gases which make their way past the rings. your engine will thank you. if you mean you just want to remove the hose thats also a bad idea as the pcv valve will not function without vaccum applied to it.
Old Jul 30, 2003 | 04:13 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I have those valve covers also, just use the PCV hole for your oil fill.
Use a small neck funnel. But make sure you have the correct P/N for your PCV on the drivers side (front) and the vacum line (rear) on the passenger side. Made the mistake and got the wrong ones first.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
