Ah whats wrong
Ah whats wrong
well guys i know that camaros rides are rough i have had two of the both without sfc. But my new iroc is off the charts. when i drive it it almost feels like im gonna fall threw the floor and it rattles alot! I had the local shop cehck it out and there saying the suspension and shocks are all good. Didnt have the bearing checked if that could be the problem? I also have 4 near bald tires coudl this be the problem? Please help Asap Thanks a bunch
no none of the bushings were looked at cuz they wanted to cahrge me for that. however, the tries are really bald and so im hoping my new kdws will help :-). thanks for the replys guys i appreciate it im sure u get stupid ? like this all the time ha but yea thanks alot. Specially u vader u have answered alot of my stupid ? over the past few months and ive become alot more knowledgeable cuz of it thanks and keep up the good work!
I think you might be confusing an "inexperience" question with a "stupid" question.
"Inexperience" is the lack of history or understanding within a given subject, and can usually be solved easily by asking the right questions.
"Stupid" is almost impossible to cure, since that's usually the result of NOT asking questions.
BTW - I've done some pretty stupid things by assuming I knew the answer. Funny how the level of stupidity is often duirectly proportional to the cost of solving the "Stupid" action.
I drive a 94 silverado with a hell of a load on it, I have to pump the tire up to 80psi (yes they are rated for that).
When I remove the load, and the tires are still aired up it feels like I am on a riding lawn mower in a boulder field.
Did you check your tire pressure? If they are over inflated youin for some terrible wear, and the worst ride of your life.
I once went into a local ford/nissan dealer to have my check engine light fixed under warranty. They said I needed new shocks, and new brakes, and wanted to do the work right away for saftey.
I took it straight to goodyear to get an estimate (it was riding really rough). The guys at the ford dealership either had a bad pressure gauge, or added 85 PSI to each tire to make me think I needed new shocks, and the brake goodyear said had 40k left on them. No wonder it was riding rough, those tires were rated for 45psi
Moral of the story,
1) don't absolutely trust every shop you go to. Even the good ones make mistakes.
2) Don't trust your tire gauge unless you know or sure it's accurate.
Moral of the story,
