brake fluid in place of power steering?
Old Oct 22, 2000 | 06:31 PM
MikeS's Avatar
Can you use brake fluid in place of power steering fluid? If i understand correctly, they are both hydrolic fluids so it should be ok. The reason that I ask is the stores are closed, my power steering pump is almost empty and I only have brake fluid.
Mike
Old Oct 22, 2000 | 06:36 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Transmission Fluid and Power Steering Fluid are interchangable
Old Oct 22, 2000 | 09:24 PM
JETHROIROC's Avatar
I'd go with the ATF too, or just wait till tomorrow. Isn't brake fluid pretty corrosive to systems not designed for it? I'm not sure...go with the ATF if you absolutely have to.
Old Oct 22, 2000 | 09:52 PM
MikeS's Avatar
Thanks. I think I was thinking about transmission fluid instead of brake fluid. I think I will have to add a little ATF in the morning and then pick up the power steering fluid after work. Appreciate the help.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
