What do I torque my intake too?
Old Oct 22, 2000 | 07:10 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Putting on Edelbrock intake onto my 350 TPI whats the Torque specs for the intake bolts?
Old Oct 22, 2000 | 08:49 PM
Vader's Avatar
Mkos,
It always helps to know what year/engine you are referring to. The factory specs for the intake-to-head bolts is 15-20 ft/lbs. The intake runner-to-plenum bolts are also 15-20 ft/lbs. The throttle body-to-plenum bolts are 18 ft/lbs, and the fuel rail-to-intake manifold bolts are 18 ft/lbs. As you can see, a safe number to use for all major fasteners on the TPI intake parts would be 18 ft/lbs, and that's an easier specification to remember.
Since you're dealing with steel fasteners threading into aluminum parts, I'll throw in my usual reminder to use anti-seize compound on all the fasteners. In the same thought, if you hadn't removed the distributor bolt until the plenum recently came off, you'll be wise to anti-seize the hold-down bolt for distributor clamp as well. You'll appreciate it later. There is very little space to get a wrench in after the TPI is assembled, and you'll need all the help you can get.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 22, 2000 | 08:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Thanks Vader
Old Oct 23, 2000 | 01:11 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
15-20 ft/lbs seems light to me...I think it should be like 35 ft/lbs, have to consult a manual to be sure....
Old Oct 23, 2000 | 03:12 AM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
I believe its more like 32 lb-ft using 3/8-16 bolt with 9/16 bolt head.
Along the same line (kinda), what size is the hole on the rear/top of the block that could be used to hook up an oil pressure guage? what size threads/fitting?
Old Oct 23, 2000 | 06:07 AM
cursedz28's Avatar
pretty sure there are 2 levels of torque to be done. I thought the first was like 15lbs and the second was between 25 and 30lbs.
Old Oct 23, 2000 | 11:00 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just looked at my Helms for '89...35 ft/lbs.
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
