Quick easy question re: timing
Old Aug 1, 2003 | 10:02 PM
Thirim's Avatar
Car: 89 GTA
Engine: 350 LT1
How do you disconnect the computer so it doesn't try to advance/retard the timing? I want to see if i can squeeze a little more power out..
Old Aug 1, 2003 | 10:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well....you can't do what I think you're asking....
What you can do is disconnect the EST Bypass connector and set the base timing to your desire.
The advance is in the eprom...you'd need to burn a new curve for it to change.
Old Aug 2, 2003 | 05:29 AM
ede's Avatar
ede
to answer your question, pull the fuse to the ecm. i doubt if you like the results, but who knows you may like all your new found power, or lack of as the case may be.
Jorlain
Aug 24, 2022 05:11 PM
Dkelz313
Apr 7, 2016 10:38 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
TheJoeY88
Aug 13, 2015 06:51 PM
