Ill post in here since no1 did in tpi need Help with engine
Old Aug 2, 2003 | 06:15 AM
Spdfrk1990's Avatar
OK im building a 383 i want like around 450 rwhp.
I alrdy have the bottom end i want crank,rods,pistons
Now there r just some little parts i want to ask u guys where i should get them ok what about the timing chain its a 00 block roller of course zz4 crate motor block. I want a double roller where could i get 1 also what about a cam button. Oil pump and oil pan which 1's would u recamend. Its a 4 bolt main should i use main studs?? Just if some1 could list all the little things that r usually over looked and where should i get them.
i alrdy have the cam intake and heads in mind i want the cc306 cam,fast burn heads, and mini ram III.
any oppinions would be great thanx i want the engine to turn out best as possible.
Old Aug 2, 2003 | 06:46 AM
ede's Avatar
ede
maybe the reason no one has answered in the past is because it's a very simple and genaric questions you're asking. pick up a jegs catalog and you'll find everything you're looking for. reemmber you aren't in a chat room, type your words out, makes it esier to read and if it's easier to read you may get mopre response to your thread.
Old Aug 2, 2003 | 06:50 AM
Spdfrk1990's Avatar
Im sure people can read it fine and jegs doesnt show much for a double roller for the newer block. What is it with people on here get huffy over little things and i know ur gonna say u wasnt but sounded like u was. Also if it is simple that means it wouldnt be that hard to help out this is a board used for help usually.
Old Aug 2, 2003 | 06:56 AM
gmsmallblockguy's Avatar
u can get all yer parts from a paw catalouge or a local machine shop. Things tah r over looked in a 383 build are clearancing and balancing.
What size rods r u uzin? 5.7"? 6.0"? did ya know u might have some issues clearing the cam depanding on the size of the base circle?
Try a search of this board for "383" or "stroker" dude. There are alot of people who have allready asked these q's in the past even recently.
Old Aug 2, 2003 | 06:59 AM
Spdfrk1990's Avatar
ive looked alot i know about the cam n all im using 6.0 rods just wanted to know if people r usuing cam buttons and double rollers.This is my first engine build with this much hp in mind.
Old Aug 2, 2003 | 07:42 AM
fsmullet's Avatar
Stay under 500 lift and you won't have cam clearance problems. Want more lift? Get 1.6 rockers.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
