Quick Solenoid Removal Question...
Old Aug 2, 2003 | 10:15 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I need to install a heat shield on my starter (L98 engine), which requires that I remove the solenoid screws. I'm not old enough that I've replaced that many starters yet, but if I'm thinking about this correctly, isn't one of the two solenoid screws really hard to get to? I seem to remember that one is very accessible, and the other can't even be seen.
If so, will I need to drop the starter altogether just to get to that other screw, or can the screw be removed (AND replaced) with the starter in place using an extension?
Just curious--I'm trying to gague how big of a "project" this will be and if I'll have enough time to tackle it tonight.
Thanks!
Old Aug 2, 2003 | 11:26 AM
ede's Avatar
ede
i'd remove the starter first, you're going to be pretty much there anyway and the starter bolts are easy to get to, especially if you use an impact wrench.
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
injdinjn
Aug 28, 2015 12:51 PM
happyhapka
Aug 15, 2015 04:42 PM
3rdgenparts
Aug 8, 2015 07:09 PM
