Need recom on new ignition stuff >>>
Old Oct 23, 2000 | 11:02 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Currently, I have an MSD billet distributor and the MSD external coil, which both are direct OE replacement upgrade parts.
What can I install to upgrade my current equipment? MSD 6A or 6AL? or Jacobs or Accel.
What is out there for me and what options do I have?
TIA.
'87 L98 TPI IROCZ, AFR190 heads, 3.70 gears, ZZ9 cam, 2400 Art Carr TC, SLP 1 3/4" headers, SLP cat-back, no cat, no AC, no MAF screens, Accel manifold base & SuperRam, Edelbrock double roller timing chain, MSD ext coil & distributor, trans cooler, 52mm TB with airfoil, TB coolant bypass, AFPR(48psi), K&N filters, Hotchkis lowering springs, Car-Pro custom chip, Lay Ind. ram air kit, 265/45R16 Kumho V700 tires.
ET 13.39sec @ 107.21mph
'90 Eagle Talon AWD, no rust thru 9 winters
'99 Camaro SS, red, 6-spd, T-tops, Mcleod clutch, Pro 5.0 shifter, MAF processor, Direct Flow airlid, K&N filter.
313.7Hp & 320.6ft-lbf, ET 13.55sec @ 105.1mph
next mod: 4.10 rear gears
Old Oct 23, 2000 | 05:56 PM
ede's Avatar
ede
i tihnk any of it would work with what you have. i have the msd6al. i like it because it has the rev limiter (the only differance). i can use the same pills in the rev limiter as my msd shift lite.
-=ICON MOTORSPORTS=-
MM2Robinson
Oct 1, 2017 09:16 AM
sreZ28
Oct 22, 2015 08:21 AM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
Racerx974
Sep 19, 2015 10:16 AM
Jlanz55
Sep 6, 2015 02:35 PM
