Scan tools ????
Old Oct 22, 2000 | 02:05 PM
freeze92's Avatar
Scan tools ????
I am about to buy a new scan tool. Any suggestions on a brand? I have an OTC monitor 4000E, but it has been locking up, and OTC wants $575 for a software upgrade . I just want a good, user friendly version that is not terribly expensive, if there is such a thing. Anybody use an Actron?
'89 GTA, Ported Plenum, BBK throttle body, 24lb Motorsport injectors, Jet stage 2 chip, AFPR, no cats and a Flowmaster.
'95 GMC soon to be 383 daily driver w/Howell multi-point injection conversion
Old Oct 22, 2000 | 02:37 PM
Blade's Avatar
Why not get the diacom setup for 200 listed in the classifieds section ? it's an awesome tool... one of the best!
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 23, 2000 | 10:58 AM
freeze92's Avatar
That would work, but I forgot to mention that I would like OBDII capabilities, without having to spend another grand. Any other ideas?
Old Oct 23, 2000 | 08:06 PM
formula5's Avatar
I have a autoxray scanner it cost $175 through summit.It does everything the others do.Why mine was so cheap is because its for gm only w/ gm cable.Thas fine for me because all my cars are obd 1.It can be upgraded to obd2 for around 200 w/obd 2 cable I think.From what I understand is they are working on a cable to connect to a pc and download programs for crysler,ford and obd 2 from the net.They do have a web site,let me know what you think!
Old Oct 23, 2000 | 08:51 PM
ronterry's Avatar
Car: '94 Corvette
yea 'formula5' the software works good for me. It hooks to a serial port, and you need to install the flash memory. This will give you an extra option under data - (4-PC Link).
I went stupid and got the pro pak. It's all in one case. (OBD I, OBD II, Ford, Crysler, even the special cable for 94-95 OBD I/OBD II Camaro's/Firebird's/Corvette's.)
I was going to get a Actron, but the upgrades where a bit pricey, and there wasn't any support for my 94 Vette.
I like that it was bi-direction, and hoping Auto-Xray will impliement this someday. The good thing is the Easylink Auto-Xrays have a flashable memory with the PC-Link.
Believe me, If I had a lap top, I would get the diacom software and cables. My Pro-Pak cost me a whole 300 bucks.
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Oct 23, 2000 | 09:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I believe that Diacom can be upgraded to handle up to 1997 cars IIRC. I last checked a year ago and the cost wasn't too much, , around $150-175.
This is to ALL legitimatly registered software owners. I use Diacom+ (a few extra features) and I am VERY happy with it as a reasonably priced scan tool.
It works in DOS mode on your computer, so any 286 Notebook (going for peanuts, if not given away) can be used to run it. Then you can transfer data file it creates to a copy of Diacom running on your home system for extracting files into a DBase or Excel program.
When you graph the selected information, it can often show some interesting info. I use a DC-AC power inverter plugged into my cigaretter lighter, so I can run my Notebook for extended drives for capturing information.
[This message has been edited by Glenn91L98GTA (edited October 23, 2000).]
92projectcamaro
Dec 8, 2015 12:25 AM
1992Z28!
Nov 19, 2015 07:33 AM
Reid Fleming
Oct 10, 2015 09:56 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
RGB2015
Sep 20, 2015 09:26 PM
