Need advice on engine rebuild!
Old Aug 2, 2003 | 11:04 PM
KC10Chief's Avatar
I have an 88 GTA with a 350 TPI motor. It has 110,000 miles on it. I don't think the previous owners took all that great care of it. I had to replace a head gasket and it was pretty gunked up in there. It runs kind of rough sometimes, but it's never let me down. What are reasons people rebuild engines? I have a few other cars that I could drive while I'm doing this. I'd like to rebuild my engine for performance too, like adding a cam. Nothing crazy where it would idle like crap, but something a little milder than the stock cam. What other things should I replace while I have the engine out? Do the pistons need to be replaced, or can I just replace the rings? How about the bearings? When I have the engine out of my car, about how long does it take to do a rebuild if you have all the parts? Thanks for any info or advice! Matt
Old Aug 3, 2003 | 01:21 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
your going for proformance but you want a milder than stock cam?
Old Aug 3, 2003 | 04:52 AM
ede's Avatar
ede
i'm not sure you really meant to say what you did, wouldn't just a bit more cam than stock make more sense? you'd rebuild an engine when it lost compression or oil preasure usually. lot of people do to just freshen it up. last 2 engines i did both came from cars that had sit for 20 plus years. you'd only have to replace the parts that were worn, so maybe you're pistons would be ok. most likely i'd just take it +.030 and buy a set of stock replacement pistons replace the bearings nd rings cam and springs, get the heads done, change oil pump and you should be all set.
theshackle
Mar 5, 2017 06:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
E Rod
Aug 28, 2015 05:17 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
