Fuel pump conversion
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I was looking to go from my in tank pump to an external pump. Do you know of a kit to do that, I guess i'd need some sort of sump. And another question do you think a stock pump and stock filter would support about 380hp? I am wondering cause I took it to the track and it nosed over about 3/4 way down the eigth mile. Thanks.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Fuel pump conversion
i know of a couple people running walbro in tank pumps and they are pushing almost 400 at the rear wheels....
so i dont think you have to swap to a external pump yet...
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I run an External Holley pump and it can get quite loud when it gets hot. I went external since I had a carb and swapped to EFI and didn't feel like dropping the tank to install an intank unit.
I would just get a 255lph Walbro pump. My friends run that with thier LT1's and they are pushing up to 452rwhp.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if your looking to replace the pump because the car stops pulling after a while "I took it to the track and it nosed over about 3/4 way down the eigth mile" and i'd look more towards doin some work to that tpi system. they're known for that
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
