fog light question
From: First one out of liberty city, burn it to the ground
fog light question
wheres the relay for them? my fog lights have never worked and sometimes i wouldnt mind having them...wheres the relay for them? its an 88...
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6a, B&M Shifter, Transgo Shift Kit, Cold Air Induction, NEXT MOD: 5 speed...(torque convertor going so 5 speed a better idea) ..Then peeling and cracking paint..
88 Firebird 2.8
Car: Death Mobile
Engine: 666 c.i.
Have you checked the bulbs, the connections and the switch itself? Often the connection gets poor because they are exposed to the elements (up front) and people don't use a good dielectric grease to protect the connections from corrosion.
I found my lights were not going on and disassembled all the light assemblies and cleaned EVERY terminal connection in the front of the car and coated them in dielectric grease... worked good then.
If you cannot see a "light" (mines green) come on when you turn on the foglight switch inside the car, the switch itself might be broken. I've had one of those too.
