spark plugs
Old Aug 3, 2003 | 12:01 PM
johns89gta's Avatar
Car: 89 GTA
Engine: 355 TPI
spark plugs
How do I know if I have too hot of a plug? Will my knock sensor go off? Which plug should I go with my set up? I have delco's that AFR reccomended and the gap is at 50
Old Aug 3, 2003 | 09:46 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
http://members.uia.net/pkelley2/sparkplugreading.html
I gap my autolite plugs at .045 with MSD 6AL and coil.
Too hot a heat range you'll be able to see it on the plug and ping more. Possible diesling too.
Old Aug 3, 2003 | 09:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
You can go with .05. A higher performance ignition system which you have (MSD) will allow for it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
