knock on acceleration
Old Aug 4, 2003 | 02:49 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I think I might have a small problem here. The engine soudns fine through all the gears up to 4th. Its good in 5th too, until today in traffic I needed to accelerate somewhat fast in 5th gear. It started sounding wierd, what I thought was knocking a little bit. As soon as I let off the gas a little, it calmed back down. I didn't have my ALDL laptop hooked up at the time, but a previous 40 minute journey had a knock count of 47. That probably included my bad clutch skills and stalling in the driveway a few times. The count of 47 seems to have happened in a cluster. It looks like I was at a stop, and accelerated at my usual leisurely pace. It went from 9 to 47 going from 0 to 55 mph. I wasn't gunning it by any means, I was actaully accelerating quite slow.
Now is this a bad shifting problem or an engine problem? Hopefully its an easy fix I have 2 decent ALDL logs if those would help any. I don't know what to look for.
Old Aug 4, 2003 | 03:49 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You probabily "lugged the motor" a bit causing it to spark knock,
momentairly.
Use better gas.
Old Aug 4, 2003 | 04:45 PM
82camaro's Avatar
Car: 82 camaro SC
light/moderate throttle at low rpm will make 'er ping like that. Better gas and/or less timing will help. Or just don't lug it
Old Aug 4, 2003 | 07:51 PM
MechCD's Avatar
Engine: LO3, Vulcan
Ok, I normally don't have that sort of problem, so I prolly should have shifted to 4th, gassed it, and then went back to 5th..... But my clutch learning brain didn't think that way and gassed it. I could probably spare the change for the next level up gas, I am using 87 right now.
Other than the gas, no problems, just don't do it again
Old Aug 4, 2003 | 08:51 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Thats what happens when you use cheap gas.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
efiguy
Sep 27, 2015 01:30 PM
