A Serious Knock
Old Aug 4, 2003 | 04:43 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
A Serious Knock
I was driving my car going 60mph just cruising and all of a sudden I here this loud knocking sound. When I got home I noticed the sound was coming from the driver's side of the engine. I thought it was the rocker arms since they are aftermarket. ( i put a different cam in plus pushrods,lifters,and spings 8 months ago)
I pulled off the valve cover and checked the rocker arms to see if they were loose. Everything seemed to be in place. I did run the car without the valve cover to see if the rocker arms were hitting it and causing the knock. They werent. It sounds like it is in the #1 cyclinder. I think it might be interrnal.
The knock happens every few seconds.
Does anybody have any idea of what the problem could be?
Thanks.
Old Aug 4, 2003 | 04:55 PM
white91Z28's Avatar
Engine: TPI 350
i know its not the gas. ive been using 93 octane for the past few years.
Old Aug 4, 2003 | 06:14 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
piston slap? rod knock? i dunno....
does it do the noise at idle? does raising the engine speed make the noise sound louder? have u tried running the engine with the #1 plug wire disconnected? do the "knock" worsten? quiet down? or nothing?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
