Oil pressure
Old Aug 5, 2003 | 01:53 PM
Luther6704's Avatar
Car: 1986 Iroc
Engine: 305 TPI w/30,000 original miles
Transmission: 700r4 Transgo Shift Kit
Oil pressure
Sometimes when i start my car, the oil pressure will stay at 30psi even when i accelerate hard, just 30. Other times when i start my car itll be like 50 and stay up or around 45. Why is there so much variation? What could be causing this, and how much pressure should there be at idle and at wot?
Old Aug 5, 2003 | 02:24 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
It will be higher when the engine is cold. And above 1500rpm, it should always stay about the same.
Old Aug 5, 2003 | 02:38 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
A rule of thumb for oil pressure is to have 10psi for every 1000rpm. If your engine stays at about 30 all the time that is okay, but it would mean, to me, there is either a bad guage, leak, or excessive oil clearances inside the engine.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
