Timing chains, stock vs other?
Old Aug 5, 2003 | 04:14 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Heres the 2 side by side.....which one is better?
Old Aug 5, 2003 | 04:16 PM
also look how much of the difference in length the stock vs the new one................this otta be fun trying to make the new one fit.
Old Aug 5, 2003 | 04:33 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The one on the left in the pic is better.
The reason it's shorter is because of the diff. companies, and the sprockets are diff size.
That's why you buy them as a set. Cam sprocket, crank sprocket, and chain. Don't mix and match companies.
The chain on top will just use smaller sprockets. The actual size of the sprockets doesn't matter, as long as the ratio of 2:1 is kept. Another problem of mixing companies parts.
Old Aug 5, 2003 | 05:00 PM
AH! understood.....the sprockets are differents sizes....thx!
ey? is the one on the left a true roller chain?
Old Aug 6, 2003 | 06:07 PM
83crossfireZ28's Avatar
looks like it to me.. if the little cylinder things in between the links move independently of the side bar things, then it is a true roller...
Old Aug 6, 2003 | 07:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Can't tell looking at it whether it's a "true roller" or a "bushing roller".
If you paid $40 or more for it, it's probably a true roller. If you paid less than $30, it's probably junk.
If it's a "bushing roller" aka "truck chain", the stock type is better.
Old Aug 6, 2003 | 09:35 PM
well what I got was the summit chain.....part# SUM-G6601
says it a true roller, I asked and they told me it was..so i assume it is...
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Thirim
Aug 9, 2015 06:19 PM
