both fans run when reading codes
Old Aug 6, 2003 | 08:35 AM
johnnyb's Avatar
Engine: 5.7L
On my1988 IROC 5.7 I need to short 5 & 6 on the diagnostic port to read the error codes. That works fine, but whenever I do that, both fans run. I haven't seen any mention of this anywhere, and I doubt that it's supposed to be happening. Any ideas? Thanks-
jb
Old Aug 6, 2003 | 09:15 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You must be counting numbers from left to right on the top of the ALDL? Anyways, if you're shorting the two correct pins (commonly referred to as A and B..far upper right two pins) then both fans should run.
P.S.
Welcome to thirdgen.org
Old Aug 6, 2003 | 11:09 AM
bigals87z28's Avatar
Car: Check The Sig
Welcome to thirdgen.org! and i also found that out, only one of my fans turned on... i didnt know both were supposed to... oh boy... is my secondary fan/relay crap? better take myself over to electronics or cooling... Thanks newbie!! i think i found my cooling problem.
Old Aug 6, 2003 | 04:54 PM
johnnyb's Avatar
Engine: 5.7L
thanks to all!
jb
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
