View Poll Results: What sorta horsepower should i be trying to get?
Less than 350
8.70%
Around 350
13.04%
Around 400
34.78%
Around 450
17.39%
Around 500
13.04%
More than 500
8.70%
Around 400 but use nitrous at track
4.35%
Voters: 23. You may not vote on this poll
Confused...What is a reasonable amount of HP for a daily driver/weekend racer?
Old Aug 7, 2003 | 08:07 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I'm just trying to figure out what sorta crate engine i should be looking at...
This car will be a daily driver although i dont need to drive far for anything, i do live in new-england so the winters are a bitch to drive in, but for the most part i think i'll keep the car inside when its snowing out or raining really bad....
but i will be going to the track as often as i can, and i want to make some good times :-) i'm aiming for around 11 seconds......
I have thought about a smaller engine and using nitrous at the track, but i would kinda rather stay away from nitrous for now...
I'm hoping for a t56, i dont have billions of dollars, and i am willing to work on the car as much as necisary as long as its not like 5 hours every month or whatever (besides new stuff)
Please vote for what you think would be a good power to go with
Old Aug 7, 2003 | 09:15 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
List what CI you're planning to use...i/e a 400 w/500hp is much more streetable than a 350 w/500hp
Old Aug 7, 2003 | 10:14 AM
well most of the engines i have looked at have been 383's with between 400 and 475 HP built by small companies.....so a 383 is most likely what it will be......
Old Aug 7, 2003 | 03:39 PM
hmm....the 400 HP seems to be the most popular choice now.....Will a T5 transmission work with 400 HP? if so, it would be great cause i'm gonna have a hard enough time getting the money to get it done by the time in 17....if i dont have to worry much about the tranny at first, i'll be able to probably have it by next summer
Old Aug 7, 2003 | 06:40 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I think you better clarify whether you mean crank horsepower or Rear Wheel horsepower. Huge difference. Crate engines are usually rated at Crank horsepower. As an example, with a 385hp fastburn engine from GM you would be looking at maybe 330 to the rear wheels with a T56 and a good intake. IMHO, you'll want closer to 400 at the rear wheels if you really want to be able to walk the newer LS1s that have bolt-ons. 330 just isn't going to cut it. Sooooo ... that means a motor with closer to 450 at the crank.
Tim
Old Aug 7, 2003 | 07:57 PM
okay, i do mean rear wheel horsepower, and i also want to go with a carb, not FI.
thx for letting me know about the big difference
Old Aug 8, 2003 | 08:47 AM
btw are the votes for RWHP or not
tyeo098
Nov 30, 2015 06:27 PM
aharvel50
Sep 21, 2015 07:31 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Amillionoh7
Sep 5, 2015 11:44 PM
rsrookie
Sep 5, 2015 07:08 PM
