valve cover gasket install info
Old Aug 7, 2003 | 08:17 AM
grumpyvette's Avatar
a few things you should know
[1] synthetic oil desolves that yellow 3m weatherstrip gasket adhesive than many guys use over a few months time so you cant use it to glue valve cover gaskets
[2]you must use a o2 safe gasket cement like the BLACK RTV silicone cement and you must clean and degrease the cover with acetone or a similar solvent before glueing on the gasket to get the best retention
[3]you need to allow at least a few hours to over night,depends mostly on temp. for that black silicone gasket cement to set up before installing the valve covers, and placeing them gasket side down on a table with a sheet of wax paper under them and a 20lb weight on top of each valve cover while the cement sets up is the best way to insure the gaskets stay correctly aligned on the valve covers perimeter
[4]a light coat of (PAM) cooking spray on the lower gasket surface keeps them from sticking to the cylinder heads after installation
[5] these gasket retaining rings add a great deal to the valve covers ability to firmly hold the gasket WITHOUT bending SHEET METAL VALVE COVERS OR CRACKING CAST ALUMINUM VALVE COVERS AND ARE WELL WORTH THE MINIMAL COST
[6]doing it correctly the first time saves time and money
http://www.jegs.com/cgi-bin/ncommerc...07&prmenbr=361
Old Aug 7, 2003 | 08:58 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Or...
Switch the center bolt heads
Old Aug 7, 2003 | 09:31 AM
Merlin's Avatar
Or use GM silicone gaskets. They don't harden or leak with whatever lubricant you might use, and don't require sealant. They can be reused, too.
But, thanks for the tips.
Old Aug 7, 2003 | 10:57 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Centerbolts are easier...Take a alittle RTV and RTV the rubbber gasket to the cover and wallaaa it doesnt fall off and it stays in place forever.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
