Need help installing a new ignition sw..
Old Oct 25, 2000 | 07:31 AM
IROC4ME's Avatar
I need help installing a ignition switch on a 1987 IROC Z28. This switch is located on the topside of the lower part of the steering column. How do you get the park/neutral cable off of the SOB?!!
Thanks!
Old Oct 25, 2000 | 08:17 PM
Vader's Avatar
IROC,
The lock cylinder is located at the upper end of the column. The actual switch is located at the lower-middle area of the column, generally on top of the outer column tube, at the lower end of the actuator rod.
As for the park cable, fun. ain't it? It connects another actuator rod on the right side of the column that operates the shift lever gate and nterlock pin at the upper end of the column, releasing the lock cylinder to the full OFF position only when the selector is in PARK.
The diagram isn't exact for your car, but is representative.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Oct 26, 2000 | 07:23 AM
IROC4ME's Avatar
Thanks Vader!
I am trying to remove the cable from part 64 in the diagram. The only way I could remove it was to take off the part, twist it and then insert screw driver in slot! I tried everything before taking it off the column and pushing various things in the hole till I found the magic tool that worked! What a pain in the butt!
Out-Cast
Mar 22, 2019 09:39 PM
Caspar
Jun 19, 2016 11:19 PM
theurge
Aug 21, 2015 12:46 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
