my car stalls when i make a realy sharp turn.
Old Aug 7, 2003 | 11:22 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
if im cruzing doun the road and i make a quick left or right hand turn soemtimes my car will stall out.
its an 83 Z with a built up lg4 305 with a Carter afb competition series carb.
why does it do this?????????????????
Old Aug 8, 2003 | 12:14 AM
Thirdgen86TA's Avatar
How much gas you got? If it is less then a quarter tank it could dry out the fuel pump. Just an idea. Start with the easy things first.
Old Aug 8, 2003 | 06:29 PM
Wesdog's Avatar
Car: 85 T/A
Engine: Rebuilding
If you are turning the steering to full lock it could be something to do with the power steering system. You know how when you turn the wheel to the steering lock it can stutter the engine a little and make a funny noise. Try checking the fluid and belt.
The belt could be stopping the motor. when you turn the wheel all the way the power steering pump binds up and transfers that too the belt. If the rpm's are low enough it could stall the motor.
I had a monte carlo with a 3.8 6 cylinder and sharp turns at low speed would stall it out. I raised the idle a couple hundred rpm and that gave me time to keep it from dying on me. Im not an expert but that is the first thing that popped in my head when I read your post. Hope it helps.
Later,
WesDog
Old Aug 9, 2003 | 11:03 AM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
My guess is you're sloshing fuel around in the bowls and it's starving one side of the carb when you turn and pull some Gs.
I'm running the Edelbrock (Carter) 600 and if I brake really hard it does the same thing, I believe the jets / idle feeds become uncovered with fuel during high-G loads.
Holley has a fix available for their carbs but I don't know of an equivalent fix for the Carters.
Thirdgen86TA's comment about low fuel in the tank would apply to a fuel injected application but with a carb the fuel bowl is a reservoir and a momentary drop in fuel pressure should go unnoticed.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
BrianI
Aug 9, 2015 11:52 AM
killer777
Aug 8, 2015 02:47 PM
