L98 heads
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
L98 heads
can i use aset of crane roller rocker arms 1.6 ratio on a set of al. L98 heads? tthanks for any help
86 camaro 405 sm. blk. th 350 tranny 3.42 gears
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
Depends on the exact combination you are using. I'm using regular Crane 1.6 roller rockers with 7/16" studs with hardened guideplates and hardened pushrods....all non-selfaligning. ~20k miles so far...no problems. HTH
Tom
'88 Ragtop 379 SuperRam/Haltech EFI
'64 SS
http://home.sprynet.com/~ragtop88/main.htm
Tom
'64 SS
Car: '00 Chevrolet Corvette
I've got Crane Gold Race 1.6 roller rockers on my aluminum L98 heads. They're the self-aligning variety.
-Mark W.
'88 SC Camaro w/ 305 TBI
-Mark W.
Car: 86 camaro
my rockers are not self aligning -would i have to use guide plates then?
Yeah, if they are not self-aligning you'll have to convert to guideplates.
-Mark W.
-Mark W.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes you can use 1.6 rockers, but what are the specs of your cam, and your springs? You dont want to have the springs coil bind because the cam is too large. Most stock GM springs that come in our cars will work up to .480 lift safely, maybe .490. I believe the springs that come on the L98 aluminum heads are good for .510, since they use them with the ZZ3 cam.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
[This message has been edited by Kevin91Z (edited October 26, 2000).]
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 86 camaro
my cam is .447 thats why i'm going to 1.6- i'll be adding new springs thanks for all the help guys
